Looking at picking up a '66
Re: Looking at picking up a '66
Could someone here tell me what the bolt-pattern for the wheels are? The front axles are from a '68, but the rear are still '66... I'm guessing they're both the same though?
Having restored one of these myself, I recommend using this as a parts car. You can pick up a much better candidate for a little more. Unless you are really good at metal work and have a lot of time, you are going to spend quite some money restoring this one.
$300 for a parts car is a great price and it does look to have almost al of the usual hard to find pieces. Best of luck.
Cheers.
Cheers.
- TOA Membership Number: 100
Stubbe wrote:Just my humble opinion but I would look for a car that is in pretty good shape. Mine was strait with no rust but it still cost a fortune to restore I live in the western suburbs of Minneapolis and found this on craigs list
http://minneapolis.craigslist.org/wsh/c ... 90293.html
I would rather spend $5000.00 for a good one than put $20k in and iffy one
P.S. Welcome to the forum
I agree wholehartedly. Toronados are relatively cheap to purchase and very expensive to restore. Buy the very best you can afford... You´ll thank yourself later. A ´66 Toro in bad shape WILL be a money pit.
- toro_mike
- TOA Membership Number: 4
- Contact:
Twilight Fenrir wrote:Could someone here tell me what the bolt-pattern for the wheels are? The front axles are from a '68, but the rear are still '66... I'm guessing they're both the same though?
In case you didn't get the answer... This site should tell you mostly what you need - down toward the bottom are the specs from Dave Breznick's site.
http://www.breznick.com/toronado/wheels/index.htm
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
TOA #004, Webmaster
Forum Administrator
1969 W34 Toronado
