Transmission dipstick
Kendicott1
Do the '66 & '67 Toros have different transmission dipsticks? If so- why is that? I have a '66 & the dipstick is straight & flat. The finger puller snapped off so i got one for a '67 thinking their engines/ trans were indetical. The dipstick i rcv'd was about an inch longer, it was wider & it had twists in it also.
Re: Transmission dipstick
From the bottom of the washer to the tip, are they the same length? Is the full mark in the same position relative to the bottom of the stop washer?
- 66tomato
- Years Owned: Just bought a 66
Can someone with a 66 and correct dipstick measure theirs? The dipstick on mine is very fussy and doesn't seem to go down all the way.
Kendicott1
Otto Skorzeny wrote:From the bottom of the washer to the tip, are they the same length? Is the full mark in the same position relative to the bottom of the stop washer?
Back with another head scratcher. I found another trans dipstick, exact same as last one, the problem is, while checking the fluid level - car on flat surface,engine warm & running in neutral- one side of the dipstick it shows the trans fluid quart low, i look at the other side
of the dipstick, its showing way too much fluid, aprox 2" above the full mark!! What gives??
Visit vizio.com/setup for a simple and guided setup process. Whether it’s a Smart TV or soundbar, get connected in minutes and start watching. Easily configure your Vizio Smart TV or home theater system at vizio.com/setup. Connect your device, activate smart features, and enjoy unlimited streaming. Quickly link your Vizio TV or soundbar at vizio.com/setup. Go to vizio.com/setup to complete your Vizio device setup easily. Complete your Vizio TV setup at vizio.com/setup and start streaming instantly.
Seamlessly set up your Vizio home entertainment system at vizio.com/setup Go to vizio.com/setup for quick activation and device registration. Set up Vizio SmartCast devices easily at vizio.com/setup Enjoy hassle-free setup for your Vizio TV at vizio.com/setup Set up your Vizio Smart TV or soundbar easily at vizio.com/setup visit here.
Visit vizio.com/setup to quickly connect your Vizio Smart TV or soundbar. Follow guided instructions to register your device and enjoy endless streaming.At vizio.com/setup, you can set up, activate, and personalize your Vizio Smart TV or soundbar. Unlock access to apps, streaming services, and smart features. Easily configure your Vizio entertainment system at vizio.com/setup. From Wi-Fi connection to app activation, complete your setup in just a few clicks. vizio.com/setup helps you get your Smart TV or soundbar ready for use. Start enjoying your favorite shows, apps, and movies with a seamless setup process. Go to vizio.com/setup to register and activate your device. Whether it’s a TV or soundbar, enjoy fast setup and premium entertainment at home.
Set up your Vizio SmartCast TV or soundbar online at vizio.com/setup. Connect, register, and begin streaming with smart features designed for you. Activate and enjoy your Vizio Smart TV at vizio.com/setup.vizio.com/setup – the easiest way to connect your Smart TV or soundbar. Start streaming in minutes by setting up your Vizio device at vizio.com/setup. Visit vizio.com/setup to unlock apps and features on your Vizio TV.
Step-by-step guide to restore your Vizio TV at vizio.com/setup to factory defaults for smooth performance. Troubleshoot at vizio.com/setup why your Vizio Smart TV won’t turn on with quick fixes, expert tips, and simple steps to get it working again. Easily activate your Vizio Smart TV with vizio.com/setup. Connect to Wi-Fi, register your device, and start enjoying smart apps and entertainment instantly. vizio.com/setup makes it easy to connect your Smart TV or soundbar. Activate your Vizio device in minutes with vizio.com/setup
vizio.com/setup helps you link your TV to Wi-Fi and streaming apps instantly.
