CS-130 Alternator Upgrade
xgecko
TOA Membership Number: 831
Postby xgecko » Mon Sep 26, 2011 10:56 am
I found that the electric fans I installed really crushed the voltage levels with the original 10DN type alternator. After some investigation I determined the simplest solution was to upgrade to a CS-130 style internally regulated alternator and after a fair amount of looking around I found this unit that was originally specified for a 1988 Chevy Caprice Wagon with the Olds 307 engine:
http://www.oreillyauto.com/site/c/detail/ULT0/010381.oap?year=1988&make=Chevrolet&model=Caprice&vi=1037089&ck=Search_01468_1037089_2538&pt=01468&ppt=C0330
I installed it yesterday in a few minutes using this harness (Delco DN to CS - Part # W315CS):
http://www.qualitypowerauto.com/catalog.php?item=81
It took just a few minutes to remove the old alternator, find a bolt to replace the original upper bolt due to the new alternator having no threads in the small ear and installing the wiring harness adapters (they provide a jumper for the Voltage Regulator connector that jumps two contacts; you can also jump these inside the case to maintain a stock look if desired). The result is rock solid voltage at any engine speed with or without the fans cranking. I highly recommend this upgrade for all situations as it is just a much better unit that provides better voltage at low engine speeds while providing 105 amps.
mikeceli
Years Owned: Would like a 1966-67 Toronado.
OWN: 01 Corvette, 00 Ford Excursion 4x4 Diesel, 96 Impala SS, 95 Buick Roadmaster, 88 Lincoln Mark VII LSC, 86 Ford F250 4x4 Diesel, 83 Chrysler Cordoba and 79 "Bandit" Trans Am
Re: CS-130 Alternator Upgrade
Postby mikeceli » Sun Oct 09, 2011 5:36 am
Great info, especially that you included part #'s. Thanks for posting.
God Bless America!
xgecko
Postby xgecko » Sun Oct 09, 2011 6:32 am
It is a good, inexpensive and simple upgrade that significantly improves the electrical system.
You can even keep the stock look by shorting the internal contacts in the regulator.
Return to “Power train”
Users browsing this forum: No registered users and 91 guests
