CS-130 Alternator Upgrade
xgecko
TOA Membership Number: 831
Postby xgecko » Mon Sep 26, 2011 10:56 am
I found that the electric fans I installed really crushed the voltage levels with the original 10DN type alternator. After some investigation I determined the simplest solution was to upgrade to a CS-130 style internally regulated alternator and after a fair amount of looking around I found this unit that was originally specified for a 1988 Chevy Caprice Wagon with the Olds 307 engine:
http://www.oreillyauto.com/site/c/detail/ULT0/010381.oap?year=1988&make=Chevrolet&model=Caprice&vi=1037089&ck=Search_01468_1037089_2538&pt=01468&ppt=C0330
I installed it yesterday in a few minutes using this harness (Delco DN to CS - Part # W315CS):
http://www.qualitypowerauto.com/catalog.php?item=81
It took just a few minutes to remove the old alternator, find a bolt to replace the original upper bolt due to the new alternator having no threads in the small ear and installing the wiring harness adapters (they provide a jumper for the Voltage Regulator connector that jumps two contacts; you can also jump these inside the case to maintain a stock look if desired). The result is rock solid voltage at any engine speed with or without the fans cranking. I highly recommend this upgrade for all situations as it is just a much better unit that provides better voltage at low engine speeds while providing 105 amps.
mikeceli
Years Owned: Would like a 1966-67 Toronado.
OWN: 01 Corvette, 00 Ford Excursion 4x4 Diesel, 96 Impala SS, 95 Buick Roadmaster, 88 Lincoln Mark VII LSC, 86 Ford F250 4x4 Diesel, 83 Chrysler Cordoba and 79 "Bandit" Trans Am
Re: CS-130 Alternator Upgrade
Postby mikeceli » Sun Oct 09, 2011 5:36 am
Great info, especially that you included part #'s. Thanks for posting.
God Bless America!
xgecko
Postby xgecko » Sun Oct 09, 2011 6:32 am
It is a good, inexpensive and simple upgrade that significantly improves the electrical system.
You can even keep the stock look by shorting the internal contacts in the regulator.
DoodoVage
TOA Membership Number: 612
priligy genГ©rico mГ©xico
Postby DoodoVage » Fri Aug 30, 2024 2:53 pm
Minor 1 methylprednisolone decreases levels of mesalamine by increasing renal clearance <a href=https://enhanceyourlife.mom/>cialis with priligy</a> The incidence of seizure with WELLBUTRIN XL has not been formally evaluated in clinical trials
Return to “Power train”
