1967 Oldsmobile Climatic Combustion Control Air Cleaner
Pie Plate Paint Mask
Option K-50
This computer cut paint mask is used to restore the pie plate on these air cleaners used only in 1967. You can buy the mask and install and paint it yourself or you can send me your plate and I can install the mask and paint it.
Paint Mask $100.00
Labor for applying and painting plate$75.00
Shipping is extra
repainted
Original
1967 CCC K-50 Air Cleaner Plate Mask
- TOA Membership Number: 1058
- 1978 Eldorado
Re: 1967 CCC K-50 Air Cleaner Plate Mask
My 67 has the regular one with two pipes. What is this Climatic Combustion Control Air Cleaner
- Contact:
A one year only option the became standard on 68 models. The air cleaner used hot air ducted from the exhaust manifold to warm the carb on cold starts.
My 67 has the CCC air cleaner. I have all the decals for it. However, I need some parts for it. Neither vacuum diaphram works for it. Are the 68 onward close enough that the vacuum diaphrams will fit/work to open the doors on the air cleaner? Any idea where I can get these vacuum diaphrams? One was missing on the car and the other doesn't work. Don't know about the bimetallic heat sensor either.
Thanks, Tim
Thanks, Tim
