I just picked up another 66. This one is too far gone for resto but has lots of good parts.
Too much to list. Let me know what you need.
66 Parts For Sale
- Years Owned: 66 toronado, 64 jetstar 88 convertible
Re: 66 Parts For Sale
Hi, need an outside leftside remote mirror and a good interior mirror, can you help me??
Thanks Wim
Thanks Wim
Sorry but the outside mirror is not remote and the inside mirror is missing.
oke, thanks.
Do you have original carb; transmission kickdown switch; throttle cable; or choke spring, cover, and rod?
Marty
636-458-4402
Marty
636-458-4402
1968 Cadillac Deville convertible
Hello
I am looking/needing the left rear quarter glass. The trim chrome is deteriorated to the point it will not correctly hold the weatherstrip seal. I am not sure if just the chrome piece can be separated without the window… Thank you in advance. Mark Morris 703-489-6159
- FFF9BE6F-6DA9-4360-89DA-DFABC06DB231.jpeg (185.66 KiB) Viewed 37094 times
- F99E512E-B1A5-4428-9C76-8D99E751AD7E.jpeg (52.63 KiB) Viewed 37094 times
Yep I have one. I’ll call you.
Hi Tuco,
I'm looking for some parts missing on mine, any chance you have the two green pieces that are missing on the picture ?
Also the red one is quite rusty, the is the only spot on the car, do you know if it can be changed, it seems to be a part of a bigger assembly...
It's on the passenger's side.
Thanks, François.
Thanks, François.
- IMG_20190826_135438.jpg (791.33 KiB) Viewed 36947 times
The part that’s rusted is the bottom side of the inner fender. The battery sits above there in the engine compartment. They all rust out there from battery acid. I had bought another set of inner fenders and cut the good portion of the driver side and shaped it to fit pass side and welded it in.
I doubt my parts car has a good section but I’ll check. I’ll also check for the brace.
May be Monday before I can get back to you.
