WTB: The Infamous Engine, 5.7L Diesel
Postby Twilight Fenrir » Sat Oct 05, 2013 3:53 pm
Hello!
I'm looking for an old 5.7L Diesel engine :D These were found in Toronado's for a time, and I'm looking for the 81-85 "DX" block version. Preferably a known running engine, but I'll take whatever I can get. If it happens to come with a complete car, so much the better! As I'll need to use some of its other parts to make modifications...
Thanks!
spank226
Years Owned: 1967 Toronado
Re: WTB: The Infamous Engine, 5.7L Diesel
Postby spank226 » Sat Nov 02, 2013 8:43 pm
Unfortunately I didn't join and see this earlier-- I just sold my runner w/ TH400 trans for $600 (new victor reinz head gaskets, ARP stud kit, new fuel and water pumps, rebuilt IP...
I have 1 complete engine removed from a running car (that was being converted to a smog-exempt hotrod with diesel title) no transmission (stock) and I have a core shortblock. I'm in San Diego. Am new to this forum, but message me if you're still looking for one.
I should add these are all the later DX block units.
Postby Twilight Fenrir » Thu Apr 17, 2014 4:37 pm
Blah, I've been focused on other things, and never got back here...
I am still looking for the motor, and definitely want a DX block, but I'm up in Minnesota, and I can't even begin to conceive the shipping cost for a diesel engine from California to MN :P
Thanks for the reply though, and welcome (belatedly) to the forum!
Postby Otto Skorzeny » Tue Apr 22, 2014 4:21 pm
Try this company:
www.engineshipping.com
Very reasonable and professional - quoted me a little over $200 for a 1956 Cadillac engine which weighs over 700 lbs.
torogt
TOA Membership Number: 340
Years Owned: 1970 GT
Postby torogt » Sun May 25, 2014 12:30 pm
I have a 5.7 diesel engine DX block the engine came out of a delta 88. it has been out of the car for many years it was running when it was pulled out, I am in Utah
Shane A
TOA#340
1970 Toronado GT
orman_s
Postby orman_s » Fri May 30, 2014 12:04 pm
Saw this....probably not what you want since its an '80....but....
http://seattle.craigslist.org/see/cto/4447751874.html
dieting
Postby dieting » Mon Jan 05, 2015 3:42 am
You can easily check out our high quality 70-487 which prepares you well for 70-246 training center testking. You can also get success in real 70-685 course exam with the quality hodges and selftestengine.
Postby Otto Skorzeny » Mon Jan 05, 2015 3:54 pm
dieting wrote:I am still looking for the motor, and definitely want a DX block, but I'm up in Minnesota, and I can't even begin to conceive the shipping cost for a diesel engine from California to MN :P
You might be surprised at how reasonable the shipping may be.
Contact www.engineshipping.com
They shipped a '56 Cadillac V8 from Kalamazoo to Atlanta for a couple hundred bucks.
The owner of the company answers his own phone and they did a great job in the time stated. No damage.
peterr991
Years Owned: 2010
Postby peterr991 » Fri Jun 11, 2021 4:51 am
Hello like-minded, i found a cool site where you can order repaired aftermarket engine, very wide selection https://orbimotors.com/ I think it will be useful for many
Postby bcroe » Sat Jun 12, 2021 6:08 am
I have 3 Olds built with the diesel, got a lot of experience with them
before eventually changing over to an Olds 403. The most useful
info was that the diesel best be used with a switch pitch TH400 trans.
The 200 trans my cars came with very soon failed, the lockup clutch
drove me crazy. There was some kind of vacuum control on the
throttle linkage, and running vacuum thru that to the vacuum modulator
seemed to work just fine. The cars had a reputation as slugs, but I
found out why. The diesel had plenty of horsepower to launch a car,
but geared just like a gas car, the engine could not get into its power
range until something like 40mph. Using an electronically controlled
switch pitch converter set to high stall allowed the engine to rev
immediately with extra torque conversion.
In low stall for cruising it was nearly as economical as the lockup.
On a long trip with limited top speed due to weather, my 4 door
Cutlass got 30mpg. There was no issue keeping up with traffic
in the city.
There is a low miles 1980 diesel 5.7L sitting here from decades ago,
it was running but had an injector problem when replaced.
Bruce Roe. bcroe@juno.com
