How to Quickly Earn Requisition Slips in Helldivers 2 – A Player’s Guide
LunarBlaze
Postby LunarBlaze » Wed Nov 19, 2025 12:48 am
If you’ve been diving into Helldivers 2, you’ve probably noticed that earning Requisition Slips in Helldivers 2 is key to unlocking gear, weapons, and other valuable upgrades. For both new and experienced players, understanding the most efficient ways to gather these slips can save a lot of time and make your missions smoother. In this guide, I’ll break down the best strategies I’ve found, along with some personal tips that make the grind a little less grindy.
What Are Requisition Slips and Why They Matter
Before diving into the strategies, let’s quickly cover what Requisition Slips in Helldivers 2 are. These are essentially the in-game currency used to unlock premium items, upgrades, and mission enhancements. Unlike credits or other rewards you earn passively, slips require a bit more effort, so knowing how to earn them efficiently gives you a significant edge.
From my experience, prioritizing slip collection can turn a frustrating grind into a structured, rewarding process. Think of them as small investments that pay off in stronger loadouts and better mission success rates.
1. Complete Daily and Weekly Missions
One of the most consistent ways to earn Requisition Slips in Helldivers 2 is by completing daily and weekly missions. These missions often reward multiple slips at once and give you clear objectives to focus on.
Pro Tip: Don’t ignore the seemingly “easy” missions. They may reward fewer slips individually, but over time, they add up and can be completed much faster than high-difficulty objectives. Pairing these with co-op play also makes them more enjoyable and less of a solo grind.
2. Focus on High-Difficulty Operations
While daily missions are consistent, tackling higher-difficulty operations can yield larger quantities of slips. Personally, I find that playing on higher difficulties with a reliable squad is both challenging and rewarding. Not only do you get more slips per mission, but you also practice advanced tactics that make you a better Helldiver overall.
Tip: Always coordinate loadouts with your team. Certain combinations of weapons and equipment can make high-difficulty missions much more manageable, allowing you to rack up slips without excessive retries.
3. Participate in Special Events
Helldivers 2 occasionally hosts timed events that offer bonus Requisition Slips. These are often limited-time missions or global challenges. If you see an event active, it’s worth prioritizing since it’s an opportunity to earn Requisition Slips in Helldivers 2 faster than normal missions allow.
From my experience, event missions also tend to be more fun and varied than the standard operations, which makes collecting slips feel less repetitive. Keep an eye on the event timer and plan your play sessions accordingly.
4. Optimize Your Loadout for Efficiency
An often-overlooked tip is that your personal loadout can impact how quickly you can gather slips. Weapons with high mobility or area-of-effect capabilities can help you clear missions faster, reducing downtime and allowing for more missions per session.
Tip: Don’t just chase raw damage stats. Consider mobility, survivability, and synergy with your squad. A balanced approach usually results in more consistent Requisition Slip gains over time.
5. Team Up for Maximum Rewards
Helldivers 2 shines when played cooperatively. Many missions scale in difficulty but also increase rewards when more players participate. By teaming up with experienced friends or online players, you can tackle tougher objectives and earn Requisition Slips in Helldivers 2 at a faster rate than going solo.
Pro Tip: Communication is key. Assign roles, coordinate abilities, and stick together. Even a small team that works in sync will outperform a random group when chasing slip rewards.
Collecting Requisition Slips in Helldivers 2 doesn’t have to be a grind if you know where to focus your efforts. Daily and weekly missions provide steady rewards, high-difficulty operations give bigger payouts, and special events offer rare opportunities to stock up quickly. Pair that with a strong squad and optimized loadouts, and you’ll see your slip count rise much faster.
Users browsing this forum: Palmaarins and 5 guests
