New guy looking at 1966
Re: New guy looking at 1966
I found out the lights will go up and down, I don't seem to get vacuum to my headlight switch, I can pull the vacuum off the canister and hook it up to the lights and they will pop up, swap to the other line and they pop down. I notices the T with the check valve is messed up, looks like I will have to make one, shouldn't I have vacuum on one of the lines going to the switch? Thanks, Hambone
Yes, there should be vacuum to the pull switch.
Thanks Otto, looks like I will pull the switch tomorrow, at least I know the actuators work. I pulled the vac line into where it goes thru the firewall, think it is getting vac to the switch, just nothing out.
Yes, there's a little manifold there at the firewall. If your hoses are original, they're color coded with stripes to make it easy to trace. Don't pul;l the switch out unless you have to. It might be a bad hose connection or dry rotted one.
Also, don't disconnect more than one hose at a time or you won't get them routed correctly.
Well, bad news Ot, getting vac to switch, nothing coming out of other ports, tried tapping on switch with no success. Guess I will pull the switch and take it apart, there is a thread where someone pulled theirs apart, looks like it has a rubber block inside that slides back and forth, what do I have to lose? May end up calling the gentleman you suggested.
Yes. You can't make it any worse if it's not working now. That's too bad. Hopefully you'll find an obvious problem that's readily repaired like a piece of decayed rubber blocking a port or something. Maybe some silicone spray would seal things up and let parts slide freely.
With the switch out you may be able to blow out any obstruction with a short piece of hose and your lungs.
I've been looking in the online service manual for procedure to remove headlight switch, couldn't find it, can someone point me in the right direction? Wondering if the knob screws off or pops out? Thanks, Hambone
Has anyone tried one of these? Would it work? I know the original is a 3 port. https://jcaparts.com/products/1966-69-oldsmobile-toronado-2-port-vacuum-valve-headlight-switch Thanks, Hambone
Interesting. I wonder where the third hose goes? I wonder if it comes with instructions to make the modifications. I'd call the company and ask.
