New member intro- first post.
orman_s
Re: New member intro- first post.
Have fun with the vacuum lines...I'm in the process of doing that now too. Mine has the trunk popper and vacuum operated door locks as well. I have the whole dash torn apart at the moment. That is quite a task in itself.
spank226
- Years Owned: 1967 Toronado
Yea, not looking forward to that part.
Trouble-shooting the transmission no-shift issue. This is allegedly a rebuild tranny with ~200 miles on it before car was parked. Fluid looks fresh.
I removed the vacuum modulator and pulled out the valve. There was a hint of corrosion on the surface of the raised area that has the bevel cut into it. I cleaned it off with some steel wool and it took nearly no effort.
I also pulled out the governor and was able to flick the weights and see the inside valve body move enough to cover and uncover one of the openings. I'm not sure who far it's supposed to move, but it does move. (How do you get those things out of the lid/top?)
Anyway, after both of those-- still no shift out of first nor will it shift manually.
spank226 wrote:Yea, not looking forward to that part.
The most likely causes of no shift are manifold vacuum not connected to modulator, or
governor gear stripped. Getting it out of the can is easy enough (with a saw), the issue is
getting it back in. I have tried to design a machined 2 piece cover using a conventional O
ring installation seal, but not built yet.
Also check the electric kick down isn't sending 12V to the trans continuously, the lower vertically
oriented prong if you have 2. Then go for the valve body. Bruce Roe
spank226
yea, it was the 12V thing to the downshift solenoid that was causing the "problem"-- I related in another thread but appreciate you posting that confirmation here as well.
I more-or-less met my time goal and enjoyed my first real outing in 'er up in Sonoma. Some teething pains, but that's to be expected when resurrecting a car neglected/abandoned for 10 years and doing it on a pretty limited budget.
Some pics:
Some pics:
