8 Divines Per Hour—This Mapping Strategy + Build Is Fully Recorded!
StarryDawn
Postby StarryDawn » Wed Jul 16, 2025 7:30 pm
If you’ve ever dreamed of farming 8 Divine Orbs per hour in Path of Exile 2, this is the guide you’ve been waiting for. After testing countless builds and routes, we’ve locked in a mapping strategy that’s both profitable and easy to follow—even if you’re not a top-tier player. This strategy is perfect for anyone looking to farm PoE 2 currency efficiently, and yes—it’s fully recorded and tested!
Let’s break down the method step-by-step so you can replicate these results yourself.
1. Build Choice: Tornado Shot Deadeye (Bow Build)
This build is fast, has excellent clear speed, and works exceptionally well for open-area maps. Tornado Shot + Mirage Archer + Greater Multiple Projectiles means you never have to stop moving. With enough investment, it one-shots entire packs, which is perfect for high-quantity mapping.
Key Gear:
Windripper (great synergy with Magic Find)
Sadima's Touch (for quantity boost)
Goldwyrm boots (for additional quantity)
Auras: Grace, Hatred, and Precision
Flasks: Diamond Flask, Quicksilver, and a Flask with Curse Immunity
This build ensures fast clears and helps you maximize currency drops in a short time.
2. Mapping Strategy: Shaped Cemetery + Delirium Mirror
Cemetery is flat, dense, and has good mob spawns. Here’s what makes it special:
Easy layout to clear
Compatible with Delirium Mirrors, which significantly increase monster density and reward
Can be juiced with Scarabs, Sextants, and map mods
Map Setup:
Chisel maps to 20%
Use Alchemy Orbs to roll them
Apply 4 Scarabs: Divination, Harbinger, Abyss, and Delirium (if possible)
Sextant Mods: Choose “Area contains additional pack size” and “Additional strongboxes”
When paired with Delirium Mirrors, each map gives thousands of mobs, significantly boosting the chances of dropping PoE 2 currency like Divine Orbs, Chaos Orbs, Exalted Orbs, and valuable divination cards like The Saint’s Treasure or The Hoarder.
3. Inventory Tips and Loot Filter
Use a strict loot filter so you don’t waste time
Prioritize:
Divine Orbs
Raw Chaos and Exalts
Scarabs and Fragments
High-tier Essences
Dump all non-valuable loot into your stash tab quickly and re-map instantly—speed is key to hitting that 8 Divines/hour mark.
4. Why Currency Farming Over Bossing?
Bossing is cool, but inconsistent. Mapping, when optimized, is steady and scalable. You don’t need to rely on RNG-heavy drops from a single boss. With this method, PoE 2 currency rains down consistently and reliably.
If you’re looking to buy PoE 2 currency to speed up your build progression or try out new strategies, platforms like u4gm offer secure and fast delivery. It’s a great backup when RNG isn’t on your side.
5. Extra Tips for Scaling Profits
Magic Find: Higher quantity gear drastically improves returns
Level 100 Atlas Passive Tree: Focus on mechanics that increase monster spawns—Delirium, Beyond, Strongboxes, and Harbingers
Don’t Stop: The faster you run maps, the more drops you get. Avoid downtime and aim for 4–5 minute map clears
With the right build, setup, and strategy, making 8 Divines per hour isn’t just a dream—it’s a reality. Whether you're playing solo or in a group, this farming route is one of the best ways to farm PoE 2 currency. Don’t be afraid to tweak the details to fit your style—and remember, sometimes it’s okay to buy PoE 2 currency when you're short on time and long on ambition. Happy farming!
