Looking for info on a 66 Toronado Restoration
Posted: Mon Apr 30, 2018 11:27 am
by andrewblaine
Hello, I'm new to the forum and I am a student of Pennsylvania College of Technology's Automotive Restoration program. I am working on a final project, which is creating a restoration/research guide for a vehicle of choice. I chose the 66 Toronado. I am simply wondering if anyone here can give me a few details on their vehicles and the process of restoring it they went through, maybe some problems or hangups and the results. Thanks for your time.
Re: Looking for info on a 66 Toronado Restoration
Posted: Mon Apr 30, 2018 2:19 pm
by Otto Skorzeny
Andrew, do a search on this site. There are several threads detailing complete restorations - with pictures - and several showing restoration of various systems like brakes and suspension.
Here's one:
viewtopic.php?f=1&t=593
Posted: Tue May 01, 2018 1:57 pm
by Otto Skorzeny
Here's another really good restoration with pictures.
viewtopic.php?f=16&t=779
Posted: Thu May 03, 2018 12:22 pm
by Jelonek
Hallo Andrew !
that´s great idea! i do not a complitely restauration but i will make now for your pocs of my work with .... heating system, engine, lights, suspension ... we will see how can you use it ....
do you make a restauration of Toro too ? what kind of a project is it ?
big greeting from Germany ...
Wojtek
Posted: Mon May 14, 2018 8:36 am
by bcroe
A couple things that should be done. If the timing chain set is original, replace
the oft failing, engine wrecking set (with plastic sprocket teeth) with a true roller
all steel set.
Original rubber in the trans can let go at this age and ruin a lot of good parts.
Get it apart and replace the internal piston seals, etc with a $30 set.
good luck, Bruce Roe
