Wheels
Mrtoro67
TOA Membership Number: 1322
Re: Wheels
Postby Mrtoro67 » Fri Sep 28, 2018 12:50 pm
Eightballz wrote:totally interested in your cowl hood.
could you maybe post some pictures from the underside of the hood? also how did you mount the cowl scoop?
what brand / dimension did you used?
Sorry I have not returned you request, I have been ill.
Any way I bought it from Race Composits in Oldsmar, Fl
It is 37" long x21.5" wide and 2.5" high.
It was a feat to find one that fit between the hood groves. When I went to an Edilbrock carb I had to cut a hole in the hood to fit it. Brought tears to my eyes but could never get the Quadropuke to not leak.
Any way it was not hard to install
Ruffed up the paint where the scoop lip made contact. They say bare metal but bare metal always = rust. Next used self drilling screws every 2" and fastened it down.
Then took the screws out and used some automotive adhesive on the lip and screwed it back down. Cleaned off excess glue. Let it dry for 48 hours, that will depend on type adhesive you use. Next I removed the screws, sounds stupid but I used bolt head screws 1/4" if I remember right. Then comes the fun part. Use stripes of fiberglass to fill and final hold down. Hope you like what you have done because it is never coming off.
Eightballz
TOA Membership Number: 826
Re: Wheels
Postby Eightballz » Thu Oct 11, 2018 10:58 pm
oh i really like the scoop. have to do this myself since i did a complete performance rebuild on the engine and without a proper intake i'll leave some hp on the table.
so thats an fiberglass scoop i assume? hows the stiffness of the construction? i'm afraid of the paint cracking on the edges of the scoop when slamming down the hood.
dap8
TOA Membership Number: 1390
Years Owned: 1952 MG
1949 Packard
1976 Eldorado
1966 Toronado
Re: Wheels
Postby dap8 » Sun Jan 20, 2019 2:09 pm
What tires go on factory 1966 wheels?
dap8
1949 Packard
1976 Eldorado
1966 Toronado
Re: Wheels
Postby dap8 » Sun Jan 20, 2019 2:12 pm
What is meant by "drive wheel" with FWD? Should right and left be different? If so how?
Re: Wheels
Postby Otto Skorzeny » Mon Jan 21, 2019 8:50 am
The original tires were bias ply tires. If you're going to drive your car regularly and not just enter it in judged shows, you'll want to put modern radial tires on it. 235/75 R15 are the correct size. Hancook Optimo are about the only ones you can still find with a 1" whitewall.
No difference in tires between left and right side. When rotating the tires I always swap front to back and back to front on the same side of the car.
Sonny Kennedy
Re: Wheels
Postby Sonny Kennedy » Tue Aug 18, 2020 3:28 am
They are 17 x8 with Michelin 235/65-17 104H. They are not custom made just drilled and machine with a large offset. I am only in to them wheels and tires about $1,800. All done. I think it was a good deal. They still sit out a bit more then I like but don't seem to be putting to much pressure on the bearings. Time will tell. :roll:
Your wheels look amazing, Mrtoro67! I don't know, but there's just something about chrome rims that catches my attention every time. I guess it's all about the beauty that they add to the car itself.
peterr991
Years Owned: 2010
Re: Wheels
Postby peterr991 » Fri Jun 11, 2021 4:43 am
very nice car color, wheels are perfect ;)
Users browsing this forum: Bing [Bot] and 23 guests
