Hello from Germany!
Jelonek
Years Owned: 1
Re: Hello from Germany!
Postby Jelonek » Tue Sep 04, 2018 1:22 pm
so what was today ...
Jelonek
Years Owned: 1
Postby Jelonek » Tue Sep 04, 2018 1:26 pm
my plan is to cleen everything, it´s much more cheeper to buy a new one but I want to rebuilt this starter and check the funktion if after so havy disaster everything works. Parhaps i have small problem with isolation of cabels... we take a look,
I ordered parts and I have to wait now 2-3 weeks :lol:
Hello from Germany!
Postby bcroe » Tue Sep 04, 2018 1:55 pm
For a very small investment you should be able to restore that starter for
a backup. The bendix is a cheap extremely common part, probably brushes
and that copper stud from somewhere. I learned that lesson half a century
ago, now there are more backup starters, alternators, and a few other things
on my shelves, than on my cars.
Don't forget to check the condition of the flywheel teeth. Bruce Roe
Jelonek
Years Owned: 1
Postby Jelonek » Wed Sep 05, 2018 9:32 am
Hallo Bruce and everybody...
thanks!
condition of flywheel teeth is very good!, nothing is brocken, the car runs very smooooooth :P
of course I will rebuild the starter, I ordered parts and tody cleened everything.
in the winter we have a very lot of free time to do it :lol:
Jelonek
Years Owned: 1
Postby Jelonek » Sun Sep 23, 2018 5:44 am
... today I need your help becouse of ignition...
so I have now nothing to do in Toronado :roll: and I would like to check my ignition....
what ist the best point of ignition ?, how did you set your toronado´s .... 5°..7,5... or 10...or more ?
everything done/ setting with vacuum or without ?
did you check your total timing scale and timing curve?? for exemple obouve the 3 thousand turns :shock:
how can I do it with my light pistol? in the practically? is there a easy method?
I would be happy to hear something about that ..
Wojtek
Postby Otto Skorzeny » Sun Sep 23, 2018 9:15 am
I set my car to factory spec 7.5 BTDC (or as close as you can get to that with the weird timing mark and a strobe light). The car runs fine.
Disconnect vacuum advance and plug hose when setting timing. Make sure idle speed is at recommended rpm.
Jelonek
Years Owned: 1
Postby Jelonek » Sun Sep 23, 2018 11:46 am
ok.. that´s what I think 8-)
thanks Otto!
Jelonek
Years Owned: 1
Postby Jelonek » Wed Sep 26, 2018 8:48 am
I set my car yersterday by 7.5° BTDC..... much better, und very fine 8-)
and today I changed the weatherstrip rubber, my was in veery bad contition , see the picture , the job is very easy and quick,
now is the car prepared for the winter :lol:
after
and before
before
Engine Ignition Timing
Postby bcroe » Wed Sep 26, 2018 9:45 am
Glad it worked. On many of my cars the timing mark was on the harmonic
damper, mounted on a ring of rubber. When the rubber got old, the outer
ring moved around making the timing mark useless. After a couple of them
came completely apart, I replaced them on all cars with FluiDampers, can't
come apart. Bruce Roe
Postby Otto Skorzeny » Wed Sep 26, 2018 4:36 pm
That happened to me on a '66 Mustang I had in high school. The outer pulley just flew off the balancer while I was driving to work. I opened the hood and saw the belt sitting on a smooth wheel.
