so... today i finished the work.... and i´m very happy
heater core replacement ! how to do it Part1
you can everything do from engine site and without to put down the hood!!!
for small and older people: you need after that a medicine against a backpain! and musclepain or better before the work
the aircondition and heater has a constraction of two parts, it is necessary to put down only the left one ( left - driver site !!!) -
1) screw off everything from above the Heater box (cables and heater valve) , but not the small vacum! - see pics
2) crew off the 6 screws of box, nr. 5 and 6 from underneath - sorry... first you think it don´t work but it is easy and possible
3) take of a box to the left site
Hello from Germany!
Re: Hello from Germany!
- crews, nr 5 und 6 are a small "problem"
- a.jpg (219.72 KiB) Viewed 16167 times
- aircondition rechts and heater part left
- hh.jpg (215.62 KiB) Viewed 16167 times
everything put down from the box...
first carefully!!! rubber - my was in a very good condition and i use it again
then 4 small screws,
then small vacum regulater - mark the crew position!!! then flap at the front,
and than you can see your problem
- 99.jpg (100.03 KiB) Viewed 16167 times
- put it down everything
- b.jpg (250.11 KiB) Viewed 16167 times
- make a mark for the screws!
- d.jpg (228.16 KiB) Viewed 16167 times
4 small screws at the front and rear of heater and put down the broken heater
than everithing clean
and put everithing togather again
- rubber for the windows :) as a seal
- 66.jpg (229.99 KiB) Viewed 16167 times
- clean and liitle bit spray
- 22.jpg (130.28 KiB) Viewed 16167 times
I put a little bit sikaflex rubber on the ald rubber.. and to the switch space (?) to the aircondition box ( i hope you anderstand me
- sikaflex-rubber
- f.jpg (319.29 KiB) Viewed 16167 times
- sikaflex-rubber
- e.jpg (256.01 KiB) Viewed 16167 times
and put everything together in to the car .... the best are two people for the first 5 min. for the first fixation (wife, friends, dog...everybody)
from the left site, at first 2 screws upper for the first fixation.... than from under und than left seit .... but you can do like you want .....
the rest is easy .....
if you have a question ... please let me know !!!
good luck and don´t forget a medicine !!! cause of backpain
- 55.jpg (202.13 KiB) Viewed 16167 times
That does look pretty easy. I'll have to do mine before next winter.
Is the Sikaflex a silicone type sealer like the type used on bath tubs and sinks?
that with sikaflex and silikon i will check .....
sikaflex 521 uv is not a silikon... only a fluid-rubber, very stable and elastic, i use it in a home, car, everywhere, last time i repair with it my cv-rubber boots and it works perfect (i didn´t believe it... )....
Interesting. I wonder if it's available here in the USA?
Yes it is.
It's $30 + on Amazon and ebay for a 10 oz tube.
Yes it is.
- TOA Membership Number: 100
Fantastic photos! Were you able to remove the A/C / heater box with the fenders on?
