Hello from Germany!
Re: Hello from Germany!
Automatic trunk lid release. Does it work?
no Otto it work´s very good
how can i change oil in differential ? one screw to put it in i found but where is the screw to drain it???
sorry but i have a lot of questions...
-how can i take of the wonderfull clock? everything must be put down?
- how can i take of the musicspeaker on ther backseat? from insite or from trunk...
Olds manual says that periodic or seasonal changes of differential fluid are not recommended.
Unless you believe yours to be contaminated or something, I'd leave it alone. Use a suction pump to remove it if you have to.
ok thanks
now i try to solve a problem with back- and safty-neutral....lights, i found this part in bad condition swith...GM Part # 392370 see foto
question: what is inside between the plate and plastik ...i think a small contact-matallplate ?
thanks for help!
thanks for help!
- dd.jpg (1.03 MiB) Viewed 45514 times
- P1040148.JPG (162 KiB) Viewed 45512 times
- P1040147.JPG (158.5 KiB) Viewed 45512 times
- P1040146.JPG (154.5 KiB) Viewed 45512 times
- P1040143.JPG (161 KiB) Viewed 45512 times
- P1040142.JPG (155 KiB) Viewed 45512 times
- P1040141.JPG (141 KiB) Viewed 45512 times
- P1040140.JPG (157.5 KiB) Viewed 45512 times
- P1040139.JPG (155.74 KiB) Viewed 45512 times
ups... the first ist the last ....
i rescue thios part....
Looking at it the first time I figured a spring was supposed to be in there. I've never had one apart so I didn't know for sure. Good work Jelonik.
so the next one ... lamps, in EU we have another one ... see the picture,
what is the difference ? and why ?
- upper lights from US,
- lamp2.jpg (756.07 KiB) Viewed 45510 times
- in the kitchen :) new lights
- Lamp1.jpg (536.86 KiB) Viewed 45510 times
