MMOexp: How to Acquire Infuse Weapon in PoE 2
Florencehg63
Postby Florencehg63 » Thu Jul 24, 2025 8:36 pm
In Path of Exile 2, the Infuse Weapon skill stands out as a POE2 Currency unique and powerful ability available to the Huntress class through the Amazon Ascension. Unlike other active skills, Infuse Weapon is a passive skill that significantly enhances the Huntress's elemental projectile abilities, offering a deep layer of strategy and customization. By understanding its mechanics and synergies with various charge types, players can unlock a devastating elemental arsenal that can devastate their enemies.
Unlocking Infuse Weapon through Elemental Infusion
To begin wielding the power of Infuse Weapon, players must first acquire the Elemental Infusion node. This node is located in the Amazon Ascension skill tree and is essential for gaining access to Infuse Weapon. To unlock this node, players must complete either the Trial of Sekhmas or the Trial of Chaos—two challenges that test the Huntress's ability to handle various combat scenarios. Once the trial is complete, the Amazon Ascension is chosen, and Elemental Infusion is activated with just 2 Ascension Points.
This low-cost entry makes Infuse Weapon relatively easy to unlock, especially in the early stages of the game, and gives players an immediate boost to their elemental damage capabilities. As this passive skill is unlocked, it sets the stage for some of the most visually impressive and powerful elemental effects in Path of Exile 2.
Passive Activation: How Infuse Weapon Works
Infuse Weapon differs significantly from other skills in that it is always passively activated. This means that players don’t have to right-click or manually activate the skill. Instead, Infuse Weapon automatically triggers when specific conditions are met, allowing for seamless gameplay. This passive mechanic frees up valuable action buttons for other important skills, allowing players to focus on positioning and combat strategy.
However, while the skill itself is passive, it relies heavily on the player’s ability to manage elemental charges, making it both strategic and rewarding. The Infuse Weapon skill does not consume any charges on its own. Instead, it requires another skill to expend charges, triggering the infusion effect.
Elemental Infusion: The Core of Weapon Enhancement
The true power of Infuse Weapon lies in its interaction with the Elemental Infusion system. When you expend one of three charge types (Energy, Endurance, or Fury), Infuse Weapon grants the weapon a specific elemental infusion:
Energy Charges grant Cold Infusion (freezing enemies on hit).
Endurance Charges grant Fire Infusion (burning enemies over time).
Fury Charges grant Lightning Infusion (dealing burst lightning damage).
Each of these infusions significantly boosts the power of the Huntress’s projectiles, imbuing her weapons with additional elemental effects that can trigger devastating explosions upon impact.
Understanding the Infusion Process
To trigger Infuse Weapon, players must go through a specific sequence:
Generate a charge using any skill that can generate one of the three charge types (e.g., Cull the Weak).
Consume the charge using a skill like Lightning Lance, which triggers the infusion and imbuing the weapon with the selected elemental effect.
Fire a non-melee projectile skill (e.g., Twister Lance) to consume the infusion and create an explosion at the projectile’s impact point.
These explosions can deal massive area-of-effect damage, especially when used in combination with the right charge type. The 15-second cooldown on infusions ensures that players cannot stack too many at once, encouraging smart timing and efficient charge management.
Huntress Skills that Trigger Infuse Weapon
The Huntress has a variety of skills at her disposal that work synergistically with Infuse Weapon. These skills not only generate the required charges but also fulfill the non-melee projectile requirement, making them perfect for triggering infused effects:
Lightning Lance
Explosive Lance
Storm Lance
Glacier Lance
Twister Lance
Each of these skills allows the Huntress to benefit from different charge types and elemental effects, providing flexibility depending on the situation or the player's preferred build. Whether freezing, burning, or electrocuting her enemies, the Huntress becomes a force to be reckoned with.
Efficient Charge Generation in Path of Exile 2
To maximize the effectiveness of Infuse Weapon, generating charges quickly and consistently is key. The Battle Fury node in the passive skill tree is one of the best ways for the Huntress to generate Frenzy Charges—essential for infusing her weapons with lightning or cold effects. Electrocute, Freeze, or Cripple enemies to gain Frenzy Charges with each attack, creating a constant stream of infusion-triggering charges.
For players opting for the Frozen Huntress build, an additional Resonance Node can be selected to convert Fury Charges into Energy Orbs. This conversion enables players to focus on Cold Infusion exclusively, making it possible to tailor the build entirely to one specific elemental damage type.
In cheap POE 2 Currency, Infuse Weapon is a compelling and powerful skill that leverages the strength of elemental charges to create devastating explosions. As a passive skill tied to the Amazon Ascension, it offers seamless integration into the Huntress’s playstyle, allowing for high damage potential with minimal effort. By understanding the intricacies of charge management and choosing the right combination of skills, players can maximize the power of Infuse Weapon and unleash a torrent of elemental destruction upon their enemies. Whether you’re freezing foes in place, incinerating them with fire, or shocking them with lightning, the Infuse Weapon skill ensures the Huntress remains an elemental powerhouse.
