Hello from Germany!
Re: Hello from Germany!
Is there any company near you in Germany that can straighten the front bumper?
When I was at the vintage auto races at Road Atlanta, some guy took a bunch of photos of me driving around and put them on a website. A friend of mine just came across them by accident. The author obviously didn't know anything about Toronados but his pictures are good.
http://www.car-revs-daily.com/2014/05/0 ... er-purple/
- TOA Membership Number: 100
Otto Skorzeny wrote:When I was at the vintage auto races at Road Atlanta, some guy took a bunch of photos of me driving around and put them on a website. A friend of mine just came across them by accident. The author obviously didn't know anything about Toronados but his pictures are good.
Yes, the text shows that he's never driven an early Toronado. My '66 is a surprisingly nimble car that will go through twisty roads quicker than I would want to go.
Of course. Front end heavy? No. GM got the balance almost perfect with 55% of the weight up front and 45% in the rear. No torque steer or oversteer, either.
Hello from Germany!
Jelonek wrote: today a one question to transmission : which one do i
have , is that TH 425 or th400 ?? Toronado ist from 1966..
In addition, the 66-67 TH425s were switch pitch. You may note the 2 wires
going up to a mechanical switch on the throttle linkage. A few have been converted
to an electronic control, then you will find the upper trans lug wire going to a control
box. Whatever type you have, you should run the test for solenoid clicks from the
trans, with just the ignition on. It impacts driving. Bruce Roe
thanks for informations about the transmision Bruce
Otto......with my bumper.. hm if... than i have to do it couse there is no a corporation and this is no coplicated (I hope)
another reason for the driving with the Toronado
- c3.jpg (126.71 KiB) Viewed 20789 times
- B2.jpg (110.36 KiB) Viewed 20789 times
- A1.jpg (141.82 KiB) Viewed 20789 times
Jelonek wrote:another reason for the driving with the Toronado
As a Bridal car? Nice.
Hi guys
I have a small Problem with my Toro
yersterday I didn´t know that the engine works (becouse of phone !!! and noise ) and I turn on the key - hotstart
after that I cann´t start the engine again, I tryed oly one time .., now I have only a very bad niose from the starter and every cable from the battery are during the start hot.
do you know this "Problem" ?
and how do you think ... what ist wrong.... complittely starter or only magneting coupling?
thank´s
Wojtek
thank´s
Wojtek
